Hood support struts....don't last???
PaulRV6
The hood shock absorbers don't seem to last long on my 86GN. I last replaced them a couple yrs ago with GM replacements and now they won't hold the hood up. What gives with these? What does everyone else replace them with? Thanks
paul
I replaced mine with some I bought from Checker Auto Parts 3 years ago...
Still working like new.
Dito. My 86GN is once again in need of replacement hood shock ansorbers. I believe I replaced about 2 year ago also.
Yeah, I replaced mine about 2 yrs. ago with a pair from Kirbans, once again the hood will not stay up, time for another pair again.
mine with what you get at the parts stores and it has been 6 years and still hold.....knock on something..
There was a recent lengthy discussion of hood airlift cylinders at TurboBuicks.com - TR Gas Hood Struts
I prefer to use the GM # 1259327 airlifts over any of the aftermarket parts, even though it's more expensive. They do lose their compressed gas after a few years, they're essentially a consumable part :frown:
I bought mine from autozone 8 years ago and they are still working great.:smile:
Do they aftermarket ones have the same holding strength and stiffness for pulling the hood down? I have the stock hood so it's not that big of a deal but I was just wondering.
paul
paul
There have been reports of the aftermarket cylinder being too strong, and having caused damage to the hood brackets. This seems an extreme case, though. I wanted to take no chances on my "Princess", and replaced a new set of MightyLift (Autozone) cylinders with GM , just to be safe. The MightyLifts were slightly stronger (but not drastically so), but the GM cylinders are smoother in their action, throughout the full arc of the hood's swing.
I must not open & shut the hood enough, I'm still on the originals. They're tiring, though, maybe next year.
Rumbling around Pull A Part the other day and was looking at a 1987 Cutlass. They have hood hinges like a GN but use a 2 piece hood support that scissors with a spring. There is an extension bracket that mounts to the hood into which the top of the scissors/spring hood support bolts to. The other end of the hood support bolts to the fender.
Anyone ever try to adapt this type of hood support to a GN and replace the gas struts?
