Hose connection from up pipe to TB
Jack Kotlarz
Ever try to connect the rubber hose going from the up pipe to the throttle body, what a pain. Try to pull the side going to the throttle body back on itself about 1/2" or so. Like you might turn a sock down. Push it up to the throttle body and it will roll itself on without a problem.
Dont roll the hose it will damage it if it "rolls" llike a sock it has crap for internal plies.
Get a lil wd40..just a lil. and put on the upipe and slide the hose on the up pipe.
The align and slide hose forward onto the TB
Tighten the upipe clamp side of hose
Then while putting pressure towards the TB and tighten the clamp on the TB.
Then reposition the upipe conection if needed
I wish the lip on the TB was a little longer as it is a pain
