Hot Air Parts.
Rob_85Ttype
All parts priced without shipping.
The following parts are from a 35,000 mile '85 Ttype and are in great condition:
‘84-‘85 Power steering pump w/bracket - $50.00
‘84-’85 Passenger header, cracked - $25.00
'84-'85 Vacuum Block - $15.00
'84-'85 Metal coolant line assembly - $35.00
'84-'85 AC/alternator bracket - $35.00
'84-'85 Miscellaneous accessory bracket (rear of AC) - $10.00
'84-'85 Alternator to intake brace - $10.00
'84-'85 Air cleaner housing (stock) - $25.00
'84-'85 Plastic 90 degree elbow (Air cleaner to MAF) - $10.00
'84-'85 Fan Shroud - $40.00
'84-'85 Injectors, six - $40.00
'84-'85 Regulator - $20.00
'84-'85 Valve cover filler tube and breather – $15.00
G-body upper radiator bracket from Olds V8 Cutlass. Similar to 86-87 GN/Ttype but without freon line clamps attached. Perfect for hotair/electric fan/bigger radiator conversion - $30.00
Injectors
Rob. Am interested in the injectors you have for sale. Do you know if they are usable as is? I really need a set. email me if you would and if you still have them. Bernie Steffen zstef@mchsi.com
