If I had a goal of running 9.8X? @ 140+ today,would you recommend a cast wheel/journal bearing 6776 or would you recommend one of the newer billet wheeled ball bearing turbos?John Crawford ran 9.8X? @ 140+ with a Cast t04z about 10 years ago iirc.
SignUp Now!If I had a goal of running 9.8X? @ 140+ today,would you recommend a cast wheel/journal bearing 6776 or would you recommend one of the newer billet wheeled ball bearing turbos?John Crawford ran 9.8X? @ 140+ with a Cast t04z about 10 years ago iirc.
My 6776 spools so much faster since the installation of my 273 inch,9.3/1 compressioned v6. The new problem that was created was that my turbo ran out of breath at 24 lbs. I've been thinking about the Turbonetics 6465 billet for a long time and have concluded that this will be my next and last upgrade. I will finally be able to say that I don't want to make anymore horsepower. Can you imagine what it will spool like on my big engine. God help my traction issues.the 64bb billet is the turbo that is impressive to me,80+lbs/minute with super fast spool just about idled in boost![]()
To the OP's question "How did we get along before this new technology?" We were forced to because we didn't have it. Now that we have it,we don't just get along,we accel.
actually it doesnt,usually a pte.63 but it can be ordered with any3 or 4 bolt ex housingi'd be careful with that turbo unless you're swapping out exhaust housings it only comes with a .63 smaller exhaust housing..
think you have it backwards,if we are taking about spool.if its overall flow i have run a tnetics 64billet over 80lbs/a minute with both a 65f1 ex wheel and a 68f1 ex wheel on a high compression 109.The turbonetics 65f1 turbine is a turd compared to the precision 66.
shouldnt a bb smaller compressor (68mm)spool faster than a non bb bigger compressor turbo 71/76mm?he 6870 is the quickest spooling turbo I have had on my car, 7168 JB and 7668 JB are the next
how does it compare to a bb6766?now if it comes up faster than that ,to me that would be impressive as its bb to bb but the compressor and ex wheel is biggerThe 6870 is the quickest spooling turbo I have had on my car,
that is interesting.i had a similar experience just with a 5mm change on just the compressor,both had the same ex wheel,ex housing,and bb.he larger heavier compressor made that big of a spool up difference.
I thought he went 139.
The 6766 has been 151 By Jason White.
I've been 137 with a te63e.
This is the other turbo that might be in my future. If I decide on this one,I will purchase it from you. A local guy is running 145 mph with one of these. I think he's running a 130+ duration cam.The journal MFS 6766 with a larger compressor cover would be what I’d use on a V6.
230+ degrees of durationI think he's running a 130+ duration cam.
I could be wrong on the number,but it has more duration than I've seen anyone run in this forum perhaps 226-230. It has quite a lope at idle. He does it for the low rpm power loss as he races on the street. You should see how it leaves. What ever he has,it hits 145-146 in the quarter.Too much cam
how the turbo climbs as rpm rises is what was noticable to me and is one of the keys to running on the street,if left on power then no measurable difference but how much flow the turbo can deliver.The 6870 made boost as soon as i stabbed the throttle.
