How do I get SES light to turn off?(98 silverado)
TT/Ameasap
The White Blur
I have a SES light on in my truck and want to know the procedure to turning it off.
Is it just disconnecting the battery or what?
OBDII or OBDIII? Can I buy the tool to detect the code?
Any good sites to learn more about this truck?
Sorry for all the ??????
Thanks,
Bo
You can unplug the power but if the code is a "hard" code it will be stored and you will need to wipe the code. If it's a code that you can fix yourself, do so and then buy a scan tool or pay the GM dealer to clear the code. Hope it's just a O2 sensor.
OBD ll
An OBD ll diagnostic tester will read & clear your codes. However, the code will return if you haven't fixed the problem. :)
SES light is on for a reason. There is a problem which is causing emissions to be 1.5 times the EPA mandated limit for that vehicle.
Fix it, or have it fixed. Then reset the light.
