How do I remove a Stageright transbrake?
Steve
I have the pan off my trans right for the governer and I would like to remove the Stageright from my trans because I never use it. If its a really big deal I will just leave it but if it is easily removed I want to remove it. Thanks
Steve
You have to remove the valve body plus I think you would need a new seperator plate...if I remember some holes were opened up or new ones drilled...you would also need to have the original parts that were replaced...IMO I would just leave it alone...you're not going to need or use first gear for anything anyways plus the trans brake will be there if you ever decide to use it...
Thanks for the reply. I would prefer it out but if it requires all of that I will just leave it in. Thanks
Steve
