mongoosetoo
- Oct 19, 2005
Three wires, I assume one is volt in, one is volt out and the black is the ground. What are the voltage values that I am looking for? I remember most Bosch systems look for .60-.80 with ignition on and engine off. Is that right??
The car is flooding, bad. I know that if a MAF doesn't throw a signal to the ECU, it will increase the injector pulsewidth roughly by four times what it should be. SO I assume the MAF has gone bad, but I hate to just throw parts at a problem without checking it out as far as I can first.
Thanks, Brew
Thanks, Brew
