af 06
bl 38 - 40 moves around
bat 13.5
int 128
bl 133
cle 175 iac # 01 - 02
ats 116
rpm 825
tps 42
cc 40 - 238 moves around
so how do they look after 6 years it's running good for the most part , still has a slite bog and stutter / hesitation, but driveable at least. put 35 miles on it ,today , 10 by me and the rest by my 17 year old son, he has waited along time to drive it ( i was with him ) i have the boost lowered to 12psi untill i get higher octane.
in the last 6 years i drove maybe 30 miles as it ran like beyond crap. i changed maf 5 times, coil pac, plugs , wires , fuel filter, fuel reg, o2, injectors , chips, found a few vac leaks, hot wire , plenum gasket seamed to help alittle and i just changed the iac valve which seems to have been most of the problem. so today was a good day finaly as god knows i needed one.. i am still going to do a psi check thru the intercooler and hope i find a hidden vac leak so it will run the way i got it. incase you forgot my my rambbling this was to check out my scan #'s...................thanks
bat 13.5
int 128
bl 133
ats 116
rpm 825
tps 42
