Nasty Wendy
Perverted Lurker
- May 24, 2001
I need guidance. I am really close to completing my Stage 2 engine and I need to pick out a cam. I know that doing this properly involves all sorts of 'Black Magic'. I know that my goals will play into the selection but what engine specs are needed to really hit the nail on the head?
The car will be street driven so it will have to be fun in the lower rpm ranges. It will go to the track and I intend to make old church ladies cuss. The equipment is full race ported Champion GN1 heads (not Rs). Champion oncenter intake - gasket match porting. 6.5" Oliver Rods and Wiseco Pistons. I'll have to cc the dish of the piston or call Wiseco because I don't remember what the dish is on these. It is an On Center 153. Obviously the cc on the piston will be needed as well as other piston measurements to determine the compression ratio as well as the headgasket thickness. I want to use the thinnest headgasket I can to maximize quench but I do understand that compression ratio may dictate otherwise. The total cubic inch volume of the engine is 276.12 in³. The bore and stroke is 4.040" and 3.59". I have a Vigilante 9" 7 disc lock up converter with a zero pump that I'd like to use if possible but I won't sacrifice anything to not buy a different converter however I'd like to stay with a lock up. I know that if this turns out right then eventually the 200r will bite the dust and I'll have to go to a 400. I need to know how to select the right HYDRAULIC roller cam for this application. Thanks to all who can give me some insight. The engine was machined by Duttweiler and is complete now minus frontcover/oiling/cam.
