The EGR valve should only open above idle when the engine is warmed up, if it opens at idle it will at least cause a rough idle, but usually cause the engine to stall. If you have vacuum to EGR at an idle then there is something wrong. Maybe a bad solenoid, a wiring problem or a computer problem
