- Feb 14, 2002
Depends upon the fluid which is used to rate the injectors. Sometimes the spec reflects n-heptane test fluid, sometimes not.
Technically it also matters which fluid you are using in the vehicle. E85 is quite a bit denser than gasoline, so on a lb/hr basis the numbers are higher assuming volume is the same
