i give the stock a lot of credit ,
ran 12.0s for years on stock unopened motor and turbo and even went low 11s before the cam lobe gave up and had over 130k
at low 12.xs the trans went , and you call that a simple refresh like its a couple dollars , maybe a couple $1000 these days. and you better have another means of transportation or you may find your self unemployed
.I ran my 86 with stock block (crank rods pistons etc) for many years at low 10s (bracket raced weekly not the i made one run ), but that wasnt on a 26yrold timing set or stock head gaskets or stock trans .
the point wasnt that the 3.8 is weak but it is and only through good tune can we do what we do , in stock they can tolerate a lot of mistakes , turn it upand that all changes fast
, if you cant afford to play you shouldnt
