rodman99999
- Mar 25, 2004
Good advice!!87Regal,
Read the attachment post #9 put in. It shows how the neck compares to the others. It's definatley is an improvement over stock and a cheaper way to go but it does not keep up with a stretched. I decided against the neck just because I did not want to spend a couple hundred bucks on a stock IC that I would eventually have to upgrade anyway. If you watch the boards you can pick a used stretch in the $450 range.
