Let's see how this copy and paste works. This is out of the S-10 FSM that I copied from my work CD. Refer to the gif at the bottom where I've typed in what illustration. The S-10 and G-Body share the same front suspension.
Front Coil Springs Replacement
Tools Required
J 23028-A Coil Spring Remover and Installer
Removal Procedure
SEE ILLUSTRATION 1
Notice: Use care when handling the coil springs in order to avoid chipping or scratching the coating. Damage to the coating will result in premature failure of the coil springs.
Remove the stabilizer shaft link from the lower control arm. Refer to Stabilizer Shaft Link Replacement .
Remove the shock absorber. Refer to Shock Absorber Replacement .
Secure J 23028-A to the end of a suitable jack.
Cradle the lower control arm bushings using J 23028-A .
Raise the jack in order to relieve tension on the lower control arm pivot bolts.
SEE ILLUSTRATION 2
Turn the steering wheel to one side in order to allow the steering linkage to clear the lower control arm front pivot bolt.
Remove the lower control arm pivot bolts and nuts.
7.1. Remove the lower control arm rear pivot bolt.
7.2. Remove the lower control arm front pivot bolt.
Lower J 23028-A slowly to relieve the tension from the front coil spring.
SEE ILLUSTRATION 3
Remove the front coil spring and the insulators. While removing the front coil spring, do not apply force to the lower control arm and/or lower ball joint.
Installation Procedure
SEE ILLUSTRATION 4
Install the front coil spring and the insulators on the lower control arm.
Ensure that front coil spring covers all or part of one inspection drain hole. The other hole must be partly or completely uncovered. Rotate coil spring as necessary.
SEE ILLUSTRATION 1
Support the control arm using J 23028-A .
Position the coil spring and insulator in the upper spring seat on the frame.
Raise the lower control arm using J 23028-A .
Install the lower control arm to the frame.
SEE ILLUSTRATION 2
In order to maintain adequate steering linkage clearance, install the bolts in the direction shown.
Install the lower control arm front pivot bolt and the new nut.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the lower control arm rear pivot bolt and the new nut.
Tighten
Tighten the lower control arm pivot bolts nuts with the front suspension loaded.
Tighten the lower control arm front bolt to 115 N·m (85 lb ft).
Tighten the lower control arm rear bolt to 98 N·m (72 lb ft).
Remove the J 23028-A .
Okay no shock is used as a guide. If the arm is supported properly you dont need to use it. Trying to balance the arm and spring with a floor jack can be tough to do.
My technique is a short cut. If you have the time to experiment you could try it both ways. It can be intimidating to the newb especially with all of the horror stories out there.
