how is pt 51 turbo
I've got a PT52 and have run 11.4's with this car. 50lb injectors, V4, mild head work. I've got a 3600 stall in car now but had a 3000 stall when it ran the 11.4. You might want to think about upgrading from the 009's. I've just never had any kind of good luck with those injectors.
I had one. Went 11.30's with it (heads, cam, front mount). Even from the beginning (009's, stock heads, cam, IC) I should have gone bigger. Something like a TE62.
I've got a PTE51, with good wheels, and the Bosch 42 lb. injectors. :)
Good combo. for the street and alky. racing. :cool:
3000 stall Vigilante spools great.
Raced it up to 26psi., no heads and cam.
Got at least 25K street miles on it now had it on 2 cars.
If you can find a good chip for those injectors it should work fine for you.
Maybe I have a freak 51, but mine spools kinda slow. 50s, powerstroke, 206 cam, 3000 stall.......its fine, but its not as lively as I thought it would be. See times below, on radials.
I have a pte 51 with precisions .62 housing, 50's Armstrong chip and the big neck det stock ic. Runs GREAT. Love the combo..
I had a PT51 on the TTA. Best ET was 11.61(TurboTweak), best MPH was 121.4(Thrasher 92). That was with a 210/205 cam, 50# injectors, stock heads & intercooler, 3200 Vigilante, 3" exhaust, and SMC alky kit running 93 octane, on Nitto DRs.
:D
