I am going through my ac system again - the cheap compressor I used last summer died - and have a problem.  A friend of mine did the R&R on the compressor last week for me.  Now I am flushing lines, hooking everything back up, getting ready to evacuate and charge it, and there is an electrical connector I can't get back on.  This is the two prong connector that is on the back of the clutch, so the connector slides in between the clock and the compressor housing.  Right now the lower mounting boss on the alternator support bracket that bolts to the front of the compressor is blocking this connector from going on.  Looking at the thing from the front, the connector is a little past 3 o'clock, not quite to 4.  Is that about where this connector is supposed to be?  If the whole compressor needs to be rotated 90degs that will put this connector at about 6 o'clock.  On the back side the compressor discharge is a little bit before 12 o'clock.  Is that right?  Rotating the whole compressor 90 degs would put the discharge around 3 o'clock, or a little before.
Can someone tell me if the whole compressor is clocked wrong, if maybe the clutch assembly is clocked wrong, or if everything is in the right spot and something else must be going on?
John
John
