How large of wastegate hole for 30psi?
KEVINS
My new Precision 5831 has a wastegate hole that is approx .93" diameter. I was going to use my 1.125 diameter mill bit but I can't go much larger than the .93 without the mill bit cutting into the scroll on the inside and I can't go wider otherwise the RJC DP puck won't cover the hole.
I plan on pushing around 30psi with alchy so is this hole large enough for this much boost or should I oblong the hole to make it larger?
thnx
ks
It might be too large already. Id leave it alone and see how steady the boost is at the top of 3rd gear.
Sounds good, then... Thanks for the quick reply tonight.
Kevin
