How Low Can You Go ?
Discussion in 'Brakes, Suspensions, Tires & Wheels' started by ~JM~, Jan 12, 2018.
  1. ~JM~
    ~JM~
    Expand Collapse
    Cross Member
    Oct 31, 2007
    1,754
    267
    Offline
    Anyone want to post up pics of their lowered TR along with the suspension & wheel specs?
    I'm interested in learning how low is possible, how it was done, plus how well the car drives & handles.
    Thanks.
  2. Turbo6inKY
    Turbo6inKY
    Expand Collapse
    Short Guy
    Jun 18, 2001
    995
    78
    Offline
    Not a full answer and no pictures, because I didn't lower mine much, but if you were to lower it severely and want it to still sort of work:
    1) Adjustable rear upper control arms are necessary to correct the pinion angle
    2) Adjustable front upper arms (SPC sells them) are necessary because you can't get enough shims in the stock setup or the popular aftermarkets arms (Rideteck/UMI/Speedtech) to fix the alignment if you really slam it
    3) If you want it not to bottom out all the time, the spring rates are going to need to be REALLY high. Like 800-1000 lb/in in the front, and 350+ in the back.
    Take care with shock selection, too. You need a shock with a stroke that works in the range of motion you're going to end up with and the spring rates you'll need. I never got past the first three points before ruling out lowering mine, so I have no idea where to look for the right shocks. But I do know Bilstein's motorsports division will revalve a set of their shocks for something like $200 each, so it's doable.
  3. ~JM~
    ~JM~
    Expand Collapse
    Cross Member
    Oct 31, 2007
    1,754
    267
    Offline
    Great info! Thanks.
    How's that engine build progressing?
  4. Turbo6inKY
    Turbo6inKY
    Expand Collapse
    Short Guy
    Jun 18, 2001
    995
    78
    Offline
    Slowly. But I'm close. Have a few odds and ends showing up in the mail by Tuesday, and hopefully I can start it and do the initial break in once the temperature gets back above freezing.
  5. ~JM~
    ~JM~
    Expand Collapse
    Cross Member
    Oct 31, 2007
    1,754
    267
    Offline
    Good luck! Looking forward to a blog update.
  6. turbojay
    turbojay
    Expand Collapse
    Feb 14, 2009
    654
    54
    Offline
    Ridetech single adjustable coilovers front/rear. Ridetech upper/lower control arms front/rear. The car is lowered 2" all around. The wheels are:
    Budnik Tillers 5
    Front: 17 x 8 with 4"bs 245/45-17
    Rear: 17 x 9.5 with 4.75"bs MICKEY THOMPSON ET STREET RADIAL II - 295/45-17 (Rear fenders rolled)
    There is some rubbing on the front passenger wheel when going over dips in the road.
    I am thinking of going with 18x8 fronts and 18x9 rears when the gbodyparts GNX replica rims come out.
    • Useful Useful x 1
  7. ~JM~
    ~JM~
    Expand Collapse
    Cross Member
    Oct 31, 2007
    1,754
    267
    Offline
    Same with mine. Also when turning left while backing up.
    Your car looks nice. How well does it hook & launch?
  8. scot w.
    scot w.
    Expand Collapse
    GNSperformance.com
    Feb 19, 2005
    6,958
    432
    Offline
    Customer Donnie Brooks ride with the New RideTech "Street Grip" complete suspension from us. Comes with single adjustable shocks with lifetime warranty too. 2" drop and the ride is Fantastic!
    Here is a link to it ---> http://www.gnsperformance.com/rt-coil-packages Only $2,500.00 for the whole front & rear system!
    Here is our GNS Test Car back in the day with the Full RideTech coil over suspension, Big BAER brakes and bracing... Cost of complete suspension
    system now is $4,400.00 http://www.gnsperformance.com/rt-coil-packages
    Customer Richard Townsends ride with the same complete system as our white test car $4,400.00 http://www.gnsperformance.com/rt-coil-packages These wheels are 3-piece ForgeLine's and we had the "6" ball milled into the center cap.
    We have been selling and installing suspensions on G-Bodies for many years now... We have installed and tested every suspension we sell so we know our products inside and out, we are
    Not just a place that sells anything just to make a quick buck! We know what works, We know what fits, and we know how well they hold up and perform!
  9. turbojay
    turbojay
    Expand Collapse
    Feb 14, 2009
    654
    54
    Offline
    This car's never been to the track but on street launches, it goes hooks pretty good and straight. The handling and driving experience are much better now. And I should've said I also bought this package from Scot at GNS Performance.
    • Like Like x 1
Share This Page
