How many cars runnin 10's with Erics TT chim & reg.Maf translator?
Clark6
How many are in the 10's on the stock ecm with the translator pro & the Ls1, Ls2, or Lt1 sensor? I know of Grumpy's, and Underboost I think he's runnin stock maf, Is there any one else or do they have the MAFTPRo; EXTENDER chips, OR
are the Rest and a majority of the faster crowd running a FAST Set up?
Do you mean Translator + ? because it wouldn't make a whole lot of sense to run the Translator Pro with a MAF, although it's perfectly capable of doing so. And is on other makes and models (DSM's etc.)
Running 10's with the Translator Pro and Extender Pro on a properly equipped car should be pretty easilly accomplished and I'm sure already has.
I believe Grump's running a regular Translator, not the Pro.
Anyway, there is a Translator Pro equipped car (on speed density) running in the 9's and I believe is getting very very close to tickling the 8's.
Turbo Buick MAFT Pro in the 9's........ - Full Throttle Speed Tech Support
Sorry about butting in on the thread, I just noticed you were specifically asking about TT chips.
Yeah Dave thats ok about buttin in im open to all suggestions, yes i meant the translator+ i see i made another mistake i typed chim in the post , i meant chip , i was in a hurry off to work & didnt have time to preview post this morning. Yes i know its capable with the tpro with the density tune thats what my brother is installing at this very moment, he has no alky , I do... I was thinking of something a little more simple, but who knows once he play around with his i may change my mind.
Melissa just ran in the 9s @ 138 today with a Translator and a Turbo Tweak chip :eek: DAMM... just when ya think these cars are done they go faster and quicker :eek:
Congradulations Now thats what Im TALKIN BOUT!!!
Stock ecm /TT chip, Stock MAFS -1 screen, 80* air, 24.5 psi, 1.669 60', 3600lbs. I am afraid of this engine blowing out the stock untouched bottom end or i would send it to 30 psi and run some low 10's in the 132 range. I have added a 4" MAF pipe and translator since the 10.88 which was my first and last pass with the combo since i have no roll bar. I will not get any more timed runs with this engine in this car. The only thing i would add to the combo would be a better torque converter. I believe it would pick up down low and mph better with one. It was 36* tonight and i was at 100% dc on the 50's while spraying in a lot of methanol at 24 psi. Duty cycle on the 126mph pass was around 80%. If i could have ran it tonight it would have gone over 130mph but i doubt there would be any traction.
1st pass on my combo was a 10.9 @ 125 (got kicked out)
85mm MAF, T+ and Extender extreme. Have since changed from the 85mm to 4" MAF pipe.
