pro69
- Apr 7, 2005
How many pounds of boost can a stock motor safely handle?
SignUp Now!Define stock.How many pounds of boost can a stock motor safely handle?
This question is the same as asking "How many licks does it take to get to the center of a tootsie roll pop." You guys remember that question? It took Mr Owl three licks and then he crunched it!![]()
Actually, the amount of boost for a stock unopened factory engine can be very high. This is because the amount of boost isn't getting into the cylinders as good as an engine with ported heads, intake, larger valves, better intercooler...etc. There is a point of no return when the engine doesn't make more HP with more boost. This is the reason why you can run 35psi of boost and only get into the 10's with an unopened engine. You can run much lower boost on a modded...ported heads/intake...larger turbo...larger intercooler set-up and run faster. Just remember 500HP with 30psi of boost is the same as 500HP with 20psi...it's all in how much you want to spend for upgrades.
I bought some parts from a board member who told me they have made a bunch of runs at 30 #s of boost on a stock motor, I think at low 11 second e.t.s Tune the hell out of it and it should last at least 25-30 runs.
