Plus you don't have to fill you bottle at every other stop light.![]()
That's the only downside I can see to more alky.
SignUp Now!Plus you don't have to fill you bottle at every other stop light.![]()
EDIT - I forgot to say that obviously my statements are based on running pump gas...and as a side note to the original poster you said you are thinking about trimming it back some at the track where you use C16, but trimming the alky back even more on pump gas...Sounds backward to me unless you run a way milder tune on the street (and to me the fun of alky is my tune is the same all the time, as a matter of fact I think it's safer than having a strip and a street tune because if you get the tune right and never screw with it there is less chance to accidentally forget to turn the boost down, or timing or whatever and BOOM next time you get on it on the street).
Well, I'll let you guys figure out the limits of gasoline and methanol mixes. So far, every warning or observation pertaining to methanol, no matter how short or vague the statement may have been, that I have happened to come across has proven itself out. Just keep your eyes open for failure patterns.Exactly you run pure meth...On a straight gasoline motor 10.8-11.0 is still way in the safe zone...So add some meth to the mix (still WAY less than 50-50 mix) and 10.8-11.0 is looking like a good range to stay in.
