I see you got your vacuum thingy fixed..
See if you run the car a little rich you can get away with a little more boost than trying to lean it out..In other words if you add a pound or two of FP..then you can run a little higher boost..but it comes at a tradeoff..whereas you wont make any power when the car is rich.
Ideally you want to see 760-780 for O2's at the 1320 foot mark..but getting the car to run this may require a little less boost.To lean it out and make the power..boost doesnt always =power..tune
Another thing is engine tune,engine temp,outside air temps,carbon deposits,oil in IC and intake,injector flow,timing,plug gap,turbo,etc.... All these affect knock..see wa I mean
I've hit 28lbs on alky with zero detonation..currently at 23-25 with zero on the thrasher chip..
If you were to build a turbo motor with zero deck height to quench the intake charge..it makes it almost impossible to detonate.Our pistons sit way low inside the block..but this is another topic
see ya at the track..And I hope your running a scantool..
Keep an eye on knock..or you'll be sorry ...
