How much can safely be milled of an intake manifold?
Sleeper
I'm working on a 4.1 stage motor and have Champion irons and Felpro 1000's on it.
Since the deck height is different between the stage 1 4.1 and the 3.8, ( I think it's .025) I see that the intake needs to drop a bit lower to fit.
How much can safely be taken off the intake?
How do I calculate the amount to take off?
You can kinda see in the pic where the intake bolt hole lines up with the head bolt hole.
you can get thinner (and thicker) intake gaskets from TA performance
they show an .016, .031, .047 ,.062 (close to stock)
Thanks.
I think my issue is that I went with thinner head gaskets Felpro 1000s (.039,) VS stock thickness (.063) Plus the different deck height between the 4.1 Stage and 3.8 (.025)
So options are, try to mill the intake to fit, or pull the heads and gaskets and go with Cometics, but need to figure out the thickness that I need to get proper manifold clearance.
Thoughts?
do the ports mismatch as bad as the bolt hole?
Is this Pic without a gasket?
Have you determined compression ratio ? today we try to get as much as posable but losing a half a point of CR is better than cutting the intake in my opinion. Intakes do cost less than ported irons but the day is coming intakes will be very hard to find. Actually that day is here.
I didn't really take the time to look that far after seeing there was a bolt hole issue.
Yes, without the gasket.
I figure 8.5-8.8 I'm lucky enough to have picked up a few spares over the years, so I could sacrifice one, but I hear you about their scarcity.
I just dread having to pull the heads off again and figure out what thickness of Cometics I will need.
if I remember correctly the ported irons the port was raised maybe you can oval the bolt hole and lower the port for a good match, if the top of the port has a good match already.
Thanks. I'll take a look at that. One of the spare manifolds that I have is virgin with no port matching, so could use that to match the head ports. I'll check my ported one first to see how close it is.
