How much oil does rear hold with ta girdle?
I got over 3 quarts in there already and it's still not level with the fill hole.
If you fill it to the top hole in the rear cover (TA cover), it will be over filled. Remove the factory inspection/fill hole plug on the right side of the center section and fill the rear end until the fluid comes out of the factory inspection/fill hole.
