...Specifically the drivers side. If read correctly in another thread,someone said the drivers gets the least amount to begin with,that and these rockers are on a shaft and oil differently than say a chevy 350?. Anyway heres a little story-I changed the oil with 10w 30 and could only locate a stock listed size(as in half the size of the old AC Delco previously on there)fram filter and thought I'd only run it for an hr or so until I got to Napa and could get a proper filter-kinda an extra little filter benefit thing for 5 bucks I reasoned.
-so I did that and with the engine running-the oil pressure was good on the gauge but there was ticking in the drivers valve cover and then the car was running rough to an almost stall,then the check engine light came on. Sooo I put the old filter back on and the engine light did not come on again. Obviously at this point I was worried. Looking in through the oil filler hole it its dry in there-I can wipe my finger around and not even a film.
The stock engine has like 15k miles on it. That ticking is still there although seemingly less. I first thought it may be a exhaust leak or something and was going to check after changing the oil etc. It still wants to almost stall/miss like when I first got the car. I was going to do a new gas filter,plugs etc.
