I made my own.  Used a water osmosis purification tank to hold the alcohol.  These tanks have a schraeder valve for air pressure at the base and a tube on the top where you can pour the alcohol.  I fill it full of alcohol, attach the hose, then pressurize it to about 90psi.  The hose runs from the tank (in the trunk) through a frame rail to the engine bay where it attaches to a solenoid designed for use with Nitrous Oxide.  After the solenoid is a 12"steel braided hose that runs to the nut welded over the hole in the up-pipe.  In the hole I've screwed a Nitrous Oxide nozzle and am currently running an .030 jet.  In Texas (lower altitude than here in Colorado) I ran an .024 jet.  The switch on the solenoid is attached to power on one side and a Hobbs pressure sensing switch on the ground side (and on to the ground of course).  10psi of boost activates the switch, alcohol squirts in, and I can run 20psi of boost on 91 octane Colorado gas.  Without alky I'm maxed out at about 13psi.  So far it's been very reliable.  I check the alcohol level and tank pressure every weekend.  I've got some pictures somewhere; if you want I'll e-mail them.  Hardest part is finding a tank.  I had one left over from an old water purification system that I pulled out of a house.
Keith
