- Apr 4, 2002
My boost activated, trap door, V4 SLIC, on steriods.
Here are pics of my V4 SLIC that has been on my car now for about seven trouble free years. When I first got this V4, (thanks Neal Steward AKA 750H.P.V6) I noted that the shroud had a bad choke point against the sway bar that didn't need to be there. My new shroud uses the space behind the radiator fan (there's lots) to increase air flow.
Next, I had a crazy idea to make the bottom of this shroud drop down while under boost, to help make the air inlet even bigger. It would need to be in the up position while not in boost for speed bump clearance, especially since my car sits 1" lower in the front.
Trap door shroud in up position (0 lbs boost).
Trap door shroud in down position (5 lbs boost while on the trans brake).
In this photo, you can see the differences between the stock IC on the bottom. The original V4 shroud in the middle, and the custom shroud sitting on the V4 in the top pic. Note: in this pic, the custom shroud is in the closed position, and still has a bigger opening than the V4 shroud.
Pic of shroud mocked up with trap door in open position.
Closed position.
Open position.
Closed position.
Open position, while blowing compressed air into the actuator.
A couple bucks worth of aluminun.
Closed position.
Open position.
Closed position.
