How to properly measure the compressor wheel to determine the size of the turbo?
  • Thread starter Thread starter THE RAVEN
  • Start date Start date
T
THE RAVEN
Guest
We have numerous turbos without any description as to what size they are. How can we determine the size of the compressor wheel using a caliper which reads mm. ?...T.I.A.
Before you worry about Turbo size, you should get rid of that Kenwood system. I've seen coffee tables smaller than your AMP. :)
Measure the compressor and turbine wheel in mm's and count the number of minor and major blades. Good luck! See gnttype.org for more info.
Intercooler, thank you for your reply and your referral. I will follow your advice and your link.
The Raven.
