SignUp Now!sh!t the engine is easy! I wanna see someone do a trans or a rear end!
Thanks for the info here. I have a dumb question, since Discostewie did my Alky/chip mods, the turbo spools up TERRIBLY slow.
I thought about new valve springs and a new turbo to help, but could I just rebuild mine to make it spool faster?
Again, sorry for the dumb question, it's stock motor/turbo with 62K miles on it and has DP and cold-air intake.
What needs to be upgraded to turn a stock turbo into a TA-49? Is it worth it if we then have to send the turbo somewhere to be balanced?
Nice job joey I knew something good would come out of jersey!!!!!!
Hi Joey,
The kit that I got came with a paper gasket instead of the o-ring on the
compressor back plate. Do you think I should use it or just re-use the
old o-ring? Thanks, steve
I re-used the o-ring...didn't trust the paper gasket, thanks!Id try to get a hold of the rubber oring....sorry for the delay in replying
