How to remove brake pedal?
GNRick
Retired member
Trying to remove powermaster. Can't see the bolt holding brake pedal to powermaster with all the wires in the way under the dash. Anybody know what socket size I would need, or is it a cotter pin holding it on? Thanks.
brake rods are held on with a clip similar to the one that the throttle cable is held on with only bigger , lift the open end and slide back then lift off
Are you also removing the pedal for a vacuum booster swap? The pivot bolt is a 5/8" and the nut on the other end is an 11/16".
No, not removing the pedal. Just need to r&r the master cylinder. Thanks all.
