turbov6joe
Signal 1 J-12
- May 22, 2002
What do I need to do to get the oil filter/cooler assembly off? I have a sneaky feeling that my oil leak is comming from here. I've put on 2 new pan gaskets....this last one being one of those bad azz 1/2" thick cork gaskets and there is still a leak under WOT
The leak is only on the PS, towards the front of the motor/pan, and there is oil dripping off of the starter wires. The rest of the pan is bone dry and the there are obvious signs that there is oil comming from the filter assembly.....that's GOT to be it, there is nothing else wet with oil ANYWHERE! While I had the motor apart doing the cam I started to pull the oil pump assembly apart to fill with jelly for priming purposes but could not get the thing totally apart. IS there a gasket in there anywhere that might have gone bad when I had it "somewhat" apart?
TIA
TIA
