how to seafoam hot air?
85begalttype
just a v6
doing some reading on gnttype and its recommended to cleanup inside with seafoam, but how do u do it with hot air car since u cant directly spray this into the turbo can u?
I've run it through the turbo with no issues. I like to use a vacuum hose from atop the TB to draw it in.
Hook up 2 vac. Lines and put both lines in the sea foam bottle. There is 2 ports on the intake that where to be used for alky/water from the factory. The port on the back passenger side already has a fitting so just un plug the line and hook up your hose. The other port is on the front of the intake on the driver side. Pull the cap put in a 1/8 npt fitting in there and connect hose. Then seamfoam away. One port is for the driver side bank the other port is for the passanger side bank. Good luck and have fun
And what you think about putting it in the crank case driving around for some time and changing oil and filter?
thanks guys i will try this sometime soon, seems pretty easy, just need to find those plugs in the intake now
i wouldnt, i can wash the bearings/cylinders down and mess them up on startup
i did this once and had my bearings dry on start up and spun a rod bearing.
could have already been a problem lurking and this finished it off but you never know.
