I posted previously on this but wanted to share with all of you. Instead of spending that top dollar to purchase the bushing removal tool, I used my ball joint press that I rented from Autozone for FREE (deposit required). The kit comes with three cylinders different in size. The middle size fits perfect after you hammer the lip around the end of the bushing flat. Then it fits. Of course soak the entire bushing in WD 40 or penetrating oil to make it much easier. Proceed to put the one adapter on one side and the other adapter on the other. Use a 1/2 inch ratchet though with your 7/8 socket and a cheater bar works best. The screw side should be pointing towards the front right in the center. The other way gives you an annoying exhaust pipe to work around. WORKS PERFECTLY. Once you get it as far as you can go, you can pound it outward at a 45 degree angle and it will easily pop out. A simple trick for all you stuck on this ANNOYING TASK! Plus, no special parts order. Just hit the local autozone
