TurboBuickSix
- May 23, 2001
Does the ECm need to "see" that the column is in park for the idle? If disconnected it will think the car is in gear.
My column needs adjusting and sometimes looking at direct scan I can see it is not in park,I turn the column up the rest of the way with my hand so the DS indicates park and the idle seems to get smoother.I was thinking about this when guys mentioned disconnecting the linkage but it may not make a difference.
