I'm about to have my crank mains ground and I was hoping to get some thoughts on clearances vs oil pump style.
I like the idea of running a wider clearance especially with the stock crank on a higher HP build. I am shooting for mid to low tens with my combo and figured that a little more wiggle room on the mains would be a good idea.
So I was going to tell the machinist to shoot for .002 to .0025 on the mains. My concern with this is that with the stock modded pump/cover, that I won't have enough oil psi.
Why doesn't it make sense to run the HV pump and then adjust the oil viscosity to get the oil psi you want? It would seem to me that a lower viscosity would make more sense anyway. The torque required to turn the pump is directly related to the amount of restriction posed by the oil and clearances so with reduced restriction there is reduced load and hence reduced cam bearing load (I am also now running a cam without a groove in it so I think I will be better off there).
I understand that the more oil I am bleeding off, the more windage there will be but I would prefer that hp loss over having the crank flex enough to push through the oil wedge on a tight clearanced main journal.
I'd like to hear your thoughts on this for or against
