Hydroboost conversion using Astro Van HB unit.
Great write up! Can any master cyl. work on the h/b unit as long as it bolts up correctly? I understand the shaft diameter should be 1.0'' to 1.125'' but is the m/c any different between a h/b unit and a vacuum unit?
Lots of different m/c's will work.... just make sure the piston is the correct size.... and it helps if the line size has the right threads..... or you'll need adaptors.....
so whats the size of the piston of a vacuum brake g-body master cylinder
Also do think you can use a vacuum brake pedal instead of a powermaster one
