hydroboost problems
gnloyalty877
t'squick6
I just got done finishing the hydroboost install. I have no leaks and gravity blead each wheel starting RR, RL, FR, and then FL until clear fluid runs out at each bleeder. I took the car down the road and the pedal seems alittle mushy and when i slow down the steering gets very hard like theres no fluid but its full. Any help to my trouble is appreciated. Could there still be air in the system?
Check your fluid and see if you have tiny bubbles in it. If you do, you have air in the system. To bleed the air out of the hydroboost/ power steering system, cut the wheels lock to lock several times with the car running. Let the car sit overnight for the bubbles to dissipate and you should be good to go.
