Gene Van Horn
- Feb 20, 2013
GN87, thanks for getting back to me appreciate the effort and time.
SignUp Now!That's some set-up! Very nice. Too bad I don't have power steering.
GN87, had you tried the factory HB system before going this route? If so what where the differences in your opinion?
One question though (Slightly off topic). On my manual brake set-up, my rear residual valve is after the proportioning valve. Did I do it wrong?
Thanks. I'm about 6" away or so. That was the first section of strait tubing available. Anyway, I can't see believe a few inches of tubing should make a difference in 10 feet. Either way, I can't/wont change it now. My brake problems from previous threads are finally resolved.I wouldn't think so. The residual is there to hold back psi, and should do it on either side of the prop.
Only instructions I have, are to put it as close to the mc as possible.
subscribed....
I am interested as well but I currently have the power master system...my motor went south... and they are pricey when found. so I was looking into the hydroboost conversion. what is the best place to look for the entire kit and details to change it all over? I have searched on here quite a bit but nothing really recent....up to date places with pricing to do the conversion.
any help Is appreciated.
Damn, that's what I paid for my unit WITHOUT the m/C!!!!I ordered my kit from Tallon Hydraulics. He sells a kit with the Wilwood master cylinder. It makes life simple to just order a kit that comes with everything you need. Butch is awesome and was very helpful even after the install. Here is a link to his site. Hope this helps.
http://www.tallonhydraulics.com/sto...id=397&zenid=cbebebc38f75f5fcb640ecda4e77c8ed
Adam from Florida.
This is the same unit that I ordered from gbodyparts for the same price minus the master cylinder!!! Smdh!!!I went with Kirban's kit. My good friend/certified mechanic will be installing it for me and he didn't think it would be an overall difficult job and you keep your brake pedal. Here is the link:
http://www.kirbanperformance.com/product/44185/HYDRATECH+HYDRO+BOOST+CONVERSION+KIT+#7618.html
I know it's pricey as I think when I picked it up last year it was $100.00 cheaper.
I hope to have this installed next month as the car will come out of hibernation from it's winter nap.
