hyper pistons rods and smith bros pushrod's
limitedv6
Stage 11 in the work's
I have a set of 6 hyperutetic pistons 4.0 bore on turbo rods I ran them in a stage 11 motor for a little while but it was never beat on just a trial thing. They are in good shape and rings are still on them would make a nice 4.1 production setup. I also have a 4.1 production block std bore pistons and rod's 200.00
Smith bros pushrods 8.995 in length in orignal box 50.00
Thank's
Lots of questions. Who made the pistons and what was your deck height? Is there a part # on the pistons? Were the pistons fly cut for valve clearance? Press fit or full floating? And last, where are you located please.
I will get them out of the box and let you know all specs. I live in ky. Thank's
They are pressed on not floating. They are not fly cut this was a budget setup. They have a part number of h471p and are 040 bore. also can get you pic's if you want dont recal who made them they were in a stage 11 motor that I purchased. The motor came from Odell Cantrell I might be able to find out more it has just been a while Thanks
there TRW from doing a search and it's a 4.005 bore. I was hoping you had found the magic piston I've been looking for but they're .005 to big. Did you use them in a turbo motor?
Yes they were in a turbo motor and you are rite about the bore after i looked they were 4.005 bore sorry for the mistake Thank's
