- Feb 18, 2006
Rick here are my settings on the afr tracking page. How can know if the tracking was working or not?
min tps= 4.9
min rpm= 3200
min load= 166.4
lean lim%= 5%
rich lim%= 25%
gain= 4
afr 2000r =11.5
afr 3000r= 11.5
afr 4000r= 11.2
afr 5000r= 11.0
afr 6000r= 10.8
Dave was on that, tps needs to come down for tracking to activate. 3.80 is where I have mine. Should bring gain up also. I would say 10 at least.
I took a little ride tonight and watched maf # on my sm. I knew I wasn't crazy. At idle it's at 2. At wot 25psi boost I'm seeing 150's but in all actuality
it's in 400's like Mike said. So you were a little low. That can be tuned with the genII but you should turn the boost down and get comfortable with the setup. Do short 3rd gear blasts while watching the sensor monitor wb correction. Thats key
