I got a very good deal on a cam
DonnieShort
Who's Next?
I won this cam on Ebay a week ago, how'd I do??:D Got it today and it is very nice, getting pumped about building this motor over the winter.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7934392026&ssPageName=ADME:B:EOAB:US:6
Pretty good , huh. Here's the cam card that Comp Cams emailed me.
Cam Spec Card
_________________
SERIAL # Y 1914 SPEC CARD # 028306 SPEC CARD INQUIRY BY
SERIAL #
PART # 69-000-8 BV69 SPECIAL HYD ROLLER CAMSHAFT
CORE C69-8A BV69 BUICK EVEN FIRE V-6 DUCTILE SEMI
Special Grind
GRIND # BV6 3324S /3324S HR110.0
DURATION @ .050 INTAKE 210 ROCKER
ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 210
INTAKE 1.60
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3170
EXHAUST 1.60
VALVE LIFT INTAKE .507 LOBE LIFT EXHAUST .3170
VALVE LIFT EXHAUST .507 LOBE SEPARATION 110.0
DURATION .006 INTAKE C/L 110.0
TAPPET LIFT INTAKE 259 CAM ADVANCE 0
TAPPET LIFT EXHAUST 259 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 5- RECOMMEND VALVE SPRINGS
VALVE OPEN EXHAUST 35 DEPARTMENT R
VALVE CLOSED INTAKE 35
VALVE CLOSED EXHAUST 5- SPC INSTR FOR CUSTOMER
INTAKE LOBE ID 3324S GRIND INSTR FOR CAM SHOP
EXHAUST LOBE ID 3324S
DATE SETUP 10/23/2002
Seems like a pretty good deal and very nice cam.
Errr... PTE roller cam... Getting a bad feeling here... Hope for your sake it's the "new" style, not the old!
From the pic and at the none timing gear end of the cam, it looks cast. If that fuel pump eccentric, is part of the cam, and not bolted on, I'd be really worried that it's an econo roller.
I may be wrong, but, it's hard to tell from the photos exactly what it is.
I have a few cam cards floating around here, it's the stamping on the end of the cam that matters.
What all is it that you have to look for do determine if it's the ductile roller or not?
I had Comp Cams and Dan at PTE run the serial number for the specs and both said that it is the new ductile roller.
PTE never made a ductile roller to my knowledge.Same thing I thought when I saw the pic,budget roller just because its cast(never even seen one in person).The only ductile roller cam made is not sold thru PTE,just Comp.All the others just sell billet rollers.
PTE does sell the "austempered" cams along with the billets.
From Darrell at Comp Cams
This is a Ductile Core. I also asked & it is not a Budget or Econo style cam.
You should be fine.
Donnie and Heather wrote:
> Darrell, can you tell me if this cam is the new ductile roller? A few
> internet friends seems to think it may be one of the Budget or Econo rollers
> that PTE ( Precision Turbo ) sold a few years ago that wiped after a few
> hundred miles on a ton of customers cars. Just need some piece of mind.
> Thanks!! Serial number is :
> Y - 1914
> Thanks! Donnie
> Donnie
> ----- Original Message -----
> From: "Darrell Miles" <damiles@compcams.com>
> To: <donnieandheather@alltel.net>
> Sent: Monday, November 29, 2004 3:35 PM
> Subject: Spec Card
> > SERIAL #
> > Special Grind
> > ARM RATIO
> > INTAKE 1.60
> > EXHAUST 1.60
> > Tab For Next Serial Number, (A)dditional Operations, Additional (I)nfo:
