i got problems part 2
roderick
my car is not running rite so i took off the top of intake and i have a pool of gass in there. i have stock injectors and stockfuel pump everything is new except injectors. as you can see i have the worst luck.
clean up the gas in the intake then put a fuel pressure gauge
on the fuel rail. start car.fuel pressure should be mid 30s psi.
shut car off and watch pressure gauge. if the pressure falls
off quickly (opsi in 15-20 min) then check your intake again.
if its flooded with gas its probably safe to assume that you
need injectors.
I don't think its possible for a bad fuel injector to allow fuel to migrate up into the upper plenum area. Sounds like your oil is really gassy and you are sucking it up through the pcv or have a bad turbo seal. You posted earlier about having gas and oil in the turbo inlet, so my guess would be a bad turbo seal and maybe bad fuel injectors or running rich, causing the oil to be gassy. Change the oil asap, Remove the rubber line going from the turbo inlet bell to the valve cover, and put a breather on the v/c. Clean it all up, and if the oil comes back, your turbo is probably smoked. Good time to upgrade!
thank you guys i appreciate your help hopfully this information will keep me from posting any more of my problems
Take the vacuum line of the fpr and see if if its full of gas. If you do this with the car running, and gas comes out of the regulator, then the diaphram in the regulator is bad.
-Jeff
Snodgrass makes a good point.. Also see your other post for a possibility..
