Mike Licht
I was here first
- May 23, 2001
I have an 18 blade 9.5" PTC here in stock that a guy did not take that I would sell for the right priceIf he has a 6776 he has plenty of turbo. The converter will most likely need to be addressed. If he's looking to drop some coin and only wants mid 10's the 6262 will cover it and spool slightly faster than the 6776. If he went with the ball bearings it would be even better. The $ spent just goes up. I've seen journal 6776 turbos spool well on the street with an 18 blade ptc 9.5". He will capture a lot of e.t with one here. At 25psi/22* the car should run 10.50's if the tune is there and he can leave hard. Valve springs should be investigated.
Mike
