Let's retrace my problems:
Sept. 2002- Car is running great!
December 2002- New valve springs.
January 7th 2003- Getting knock in 3rd gear at 15psi of boost!
January 12th 2003- Timing chain failure! Have replaced.
February 8th 2003- Hear a knock in the motor!
February 12th- Have to replace rod and main bearings! Drive the car very gingerly for over a month without any wot blasts. First time I do go wot the car shook so violently it almost blurred my vision!!! Plastic intercooler fan lost all but one of the blades! Replaced damaged intercooler and intercooler fan. One week later intercooler fan explodes again! This time I just leave it off!
May 2003- Still getting knock at 14psi of boost!
The car has not run right since the timing chain replacement back in January of 2003! Now, anything over 10psi of boost and it starts popping and cutting out!!
Have replaced with new parts or swapped out with known good parts these parts:
Turbo, injectors, coil pack, ignition module, transator and lt-1 maf, crank sensor, intercooler, tps, iac, plugs and wires, knock sensor, rocker arm, set cam sensor, also unplugged cam sensor while running with no change!!
It's been over a year since the car has run right and I've just about had it!!!!!!
That's one year and about $4000.00!!!!
Thanks for giving me a place to BITCH!!!
R.B.
R.B.
