Frank....
You are going to absolutely
LOVE it!!! So when are we going to put a roll bar in that beast of yours???
WFO, I guess I should have been more clear with my description. Basically I have a long block. Valve covers to the crankshaft (no oil pan), no lower intake but I do have the upper plenum (doghouse) and throttle body with TPS and IAC, I have the front cover, but it is wore out and I would replace it if I were to use this engine. I do not have the turbo, downpipe, or accessory brackets. The long block is complete, std bore, std/std crank, stock pistons and rods, stock heads with Kirban valve springs, and a brand new roller timing set.
The engine had 118k miles on it when I pulled it out of my 86 GN. Originally I thought the engine was burning oil but it turned out to be the turbo. I got a great deal on an engine from Shawn in Idaho so that is why I now have this engine. The missing pieces went on the new engine (which is now in the car).
As for Turbo Thunder....last year I missed it because of a conflict in dates with my daughters soccer tournament, and this year, unless I find a TB real soon, I may miss it again. If you are interested in the engine, I could possibly send it down with one of the guys going from here, or maybe drive it down myself.
