87gnintexas
Alfonso
- Jul 1, 2007
how do i fine out when my cam sensor is going out????1987 grand national
Once i use the starter fluid, it stays on but everytime i give it gas it wants to die. My pressure on my fuel regulator is set at 42 lbs. I have 40 lb injectors and a stock fuel pump but I had the car like this for 4 months and out of nowhere it's started acting up. When i drive it for up to 10 miles my check engine light comes on and it just dies, and we're back at square one... I have to use started fluid to get it to come back on. In park, it revs regular, it seems like it's working fine, but when i try to put it in gear, the problem starts.
how can i pull the code i don't know how to do that??
ok i got flashflash flashflashflash and my electric fan came????
yes Dan i change the maf sensor it work bad ass i need the chip THANK YOU ALL MY FRENDS
All your base belong to us??
