robmerrill
- Mar 30, 2009
Hi,
Sorry to start another head gasket thread but i just want to make sure.
First I had failed emissions because of little high on the HC. I had just replaced the spark plugs and the emissions guys said I should drive around in 2nd or 3rd gear and let the engine rev-up to burn the HC out of the cylinders.
So I would drive around in 3rd gear and rev-up to 3k rpms for about a mile. I did this for a few days.
Then I decided to drain the anti-freeze. I would drain, put water in the radiator, take a quick ride with heater on come back, let it cool, drain again, fill with water, take another qucik ride and drain. Then filled with 50/50 anti-freeze.
Then the next day I decided to drive in 2nd gear and got it up to to 4k rpms and push it a little to far and it went to 4.5K and then a little pop and the alot white smoke started to come out of the exhaust (like puff clouds). I got it home (I was only a 1/4 mile away) and looked under the car, clean. I opened the hood, clean. I check the oil, antifreeze, spark plugs, clean (no mixtures of oil/antifreeze). I did a quick compression check and got 145-150 on all cylinders. I also checked the turbo inlet and throttle body, clean. And no overheating.
I let it alone for a day and started it up yesterday and after a minute it started to smoke (white) and when I put it in drive it stumbled and I did not go to far. Each time I hit the gas pedal more white smoke. I checked oil, anti-freeze plugs again and all was clean. And no overheating.
I raised the car up and looked undermeath. I did notice a little oil on the bell housing (probably rear main seal).
Is this typical head gasket? How bad is it? Do you think there is more damage/cracks? Did changing the anti-freeze cause this or was it the high revs?
If this is a head gasket is there anyone in the Long Island, NY (Queen/Nassau) area that I could pay to help me change the head gaskets??
