I want to use a combination of std and .001 oversize rod bearings to obtain this clearance.
Should I have the .001 oversize(thicker) rod bearing in the rod cap with the std rod bearing in the upper portion of the rod or visa versa?
Is.007 thrust bearing clearance OK? I measured this by having the crank at the rear main w/o seal and then prying gently with screwdriver so it is pushing against the thrust bearing. I've got .002 clearance on the mains but if the thrust is excessive, can I get a thrust bearing that is oversize on the thrust surface to get something smaller , like .005? I still want to have the .002 main bearing clearance.
Thanks for your input.
Walt
Walt
