IGN-6 Six-Tower Coil Pack
seems like a silly question
its obvious you need to wire the four pin connecter that it uses to the wiring thats under the MAgnavox coilpack on the delco type1 ignition module
and then how are you going to bolt it down to the module ??
will it work?.... i dont see why it wouldnt its just a coil pack with three coils
I've always thought that the stock coil pack was more than enough to do the job. Also, this one doesn't seem to be a direct "plug-and-play" thing...you have to cut wires, etc, to connect it...It probably is a Mopar replacement coil pack.
Claude. :(
So silly answere is no, got it. Hopefully see you at Atco!
I wonder if it's specifically designed for turbo Buicks, why does it need an "adapter plug" to connect it?
Claude.
P.S: The text should say "needs a Mopar-to-Buick" adapter plug to make it work.
I'm missing something, is this a sore subject? I just asked if it's plug and play. Yes it's a cut and paste.
It's not a "sore" subject and I apologize if I made it look like that. It's more the product itself on which I have doubts...and to answer your question, no it doesn's seem to be "plug-and-play"...I went back and edited my post...
again, sorry...
Claude. ;)
