greeneyegi
- Feb 21, 2010
ordered new crank sensor,we will see the verdict,thanks for advice
SignUp Now!The crank senor is F,G & H. I don't know if that would work or not. Never tried jumping the signal. I just crank the motor.
I can tell you the crank sensor is for spark and the cam sensor is for injector pulse. It makes no sense to me how you can have injector pulse and no spark.
Try this, disconnect the coil pack from the module. Put a test light between the Blue and any of other three wires. Crank the motor the test light should blink.
RL
I had to do a search on ebay with the OEM part # for mine. It was new but no box. BE CARFUL when placing the leads back on the coil pack. I bent mine a bit to clean the contacts off and when I went to attach the ign mod wires the tabs broke off. I solder the wire to the coil pack and it works but its hard wired now.
OEM# 25526449. I know there several "different" #'s for this ign mods but I made sure the one I got was AC Delco and #25526449 was on it.
